Lose a bit.of handling, not a lot, just depends on how well ya ride.if the lose will bother ya or not. Potholes, speedbumps and that kinda stuff is a bit more.interesting too. If ya drop it Lot and have a passenger ya.may rub a bit and need a stiffer spring. If ya only lower it and an inch to inch and half should be an issue. Make.sure you lower the front and rear equally or the front a bit lower, handling is garbage with the back end lower than the front.
Sent from Droid using Tapatalk
