Does ceramic wheel bearing works that great? They are expensive
It's hard to say, but...
I put them in my friend's '18 Gsxr1k(which I store, work on, and ride)
I had put a couple hundred miles on the bike with the ceramic bearings.
I keep the bike on my Bursig stand, but also have been pushing it around for over 5 years now too, moving it here and there.
I was doing something else and needed to move the bike, I grabbed it by the bars and passenger seat strap as usual, and put the usual amount of effort in to push and pull it where it needed to go.
Immediately I noticed that this was much easier to do(I Always keep both tires 36psi cold too).
I rolled the bike back and forth several times, suprised that it was easier.
Then remembering that I had experienced this on another bike years ago.
The easiest way I can describe it is that if you have ever picked up what you thought was a near full gallon of milk, only to find out that it was almost empty, and your brain put forth the effort to lift the full jug, only to end up lifting it very quickly and easily before realizing it.
Are they worth it? It's still hard to say.
They are not really ceramic either, just a design and materials with supposedly less friction.
They are a Small part of 'every little bit counts'.
I also put ceramic transmission and output shaft bearings in that bike...which was probably good for .002 hp, lol
