MADE MY OWN HANDLEBAR SPACERS
kkbusa
I saw that someone from the org is selling handlebar risers. Looked easy enough, so I made my own using aluminum 1 inch round stock. Also went to lowes and got 3/8 by 16 by 3 inch long bolts. Made two set of spacers, one 5/8 and one 1 INCH LONG. Put the 5/8 on first to try it out. I went for a good ride they helped out a lot, but I noticed more vibration thru the bars. I ended up puting two plastic inch and 1/4 spacers where the stock handlebar assembly rests over the top of the fork tubes, then I made an inch and 3/16 long. After putting them on the vibration went away. So if you only put the four spacers on beware of the vibration because this is nothing under the handlebar assembly at the end holding it up..
