While at the drag strip 11-17-07, Texas Raceway Kennedale I raced my 08 against an 07 Busa, somewhere near the end of the run his chain broke and wrapped up around his counter (front) sprocket and busted his motor case, oil all over the track. I looked at it and it appeared that there is a removable case behind the front sprocket so maybe he won't have to tear the entire engine down. But I said that to say this, Maintain those chains boys, I clean and lube mine after every ride and adjust as necessary. I bet that dude wishes he would have.
I made 12 passes, best was 6.742 @ 112.47 in the 1/8th. I spanked a ZX10, Gixxer 1K, first Gen Busa and several others. I got spanked by two stretched and lowered "drag bikes" but beat all stock length bikes that I ran.
The Boo is hard to get out of the hole without wheeliing, and sometimes if it hooked in 2nd it would carry the wheel about 6 inches off the track all the way thru 2nd, felt awesome, other times it would break loose in 2nd and smoke the tire all the way thru. It speed shifts nice thru the gears and felt real stable. It never overheated even when I made five passes right in a row without stopping the engine. Mine was the only 08 that showed up so it got quite a bit of attention being all bike drags that day. I guess the slipper clutch worked fine cause I was having to get out of it pretty quick at the big end and I never had any wheel hop.
OK, clean/lube and adjust them chains.
