Bruce Bell
I've started hearing this clunking sound when coasting like down a hill. I took it home put it on the rear stand and let it run in gear. It's not in the motor, I'm pretty sure of that. I watched the chain and it's not always smooth, it jumps. The chain looks fine and so does the rear sprocket, I can't see the front one. So if the chain looks OK, what could it be? Is it normal when in a low rpm it chugs and makes the lashing in the transmission transfer into the drive tranny? Anybody else have this issue? Or is it normal. Is it in the clutch? I know there is that part in the clutch that slaps around, I've hear of guys welding it so that it doesn't do that. Could there be something going on with the out put shaft that holds the front sprocket, is there any of these issues with this bike? 2006 with 14,000 miles. Thank you.
