Motor could probably answer this best. I would try what you have 1st, on the street, then dyno. I have found there is a difference from street to dyno setups. I don't think a static dyno loads the engine enough, IMO.
OK---I have full TMH box mod, PC2 w/ 007HARV map, Sato pipe. By Monday the airbox will have all long stacks sitting on cleaned up bores Tbodies(NOT bored out, just lip and notch removed).
You tunerdudes think the map could use any tweaking?
