Im using a map file that one of the guys on here sent to me. It seems to work fine for my setup, but at 0% throttle, it will sometimes stall.
Most of the time when pulling up to a light, when I pull the clutch in it will stall or sometimes when you rev it up and then go to 0% it will stall.
Also at idle it seems to be running a little rough and my RPM is I would guess around 800 to 900.
If I use the fake choke or give it a little throttle it clears up.
She is also very cold natured, but I'm guessing it is the map causing that too.
I have Full 421 Muzzy, KN air filter, Airbox mod, pairvalve mod(gone).
I tried the standard Muzzy file from PC3 site, but it was too rich.
Any ideas on what I should change in the map to stop this.
thanks
thanks
