202mphbusa
On my current standalone
Staged injection I set the parameters to turn them on
I used 6k RPM Switching point, Not switching off primarys
so when I hit 6k the secondaries start spraying and Primarys keep spraying
I am confused with some of the maxxEcu staged settings
First setting "When primarys max out then the secondaries start"
Second Setting Manual control of secondary injectors (extra fuel table 1) So secondaries spray all the time based off Secondary table
Third Setting Primary/secondary injector changeover (extra fuel table 1)
any one have any experience ?
Staged injection
warning/information Warning Incorrect settings of the injection staging system can cause the engine to run lean. Double-check all settings and test the engine under controlle
www.maxxecu.com
