MC Express Turbo vs Mr Turbo (long post)
OB_gsxr1300
Just got back from Motorheads shop, and seen his MC Express Turbo..
If you are in the market for a turbo, you should REALLY take a serious look at this unit. Although it is pricey, in this case you do get what you pay for!
Some observations, the Turbo is a heavily modified Mitsubishi G13 (off of the 3000GT's), this Turbo is a "Hybrid". If your familiar with Garrett turbos, "Hybrids" are turbos that incorporate the best features of several models into one.The exhaust housings are heavily modified, allowing the use of a larger compressor wheel, increased bypass valve volume etc. This turbo also utilizes water cooling, the centersection of the Turbo is cooled by a radiator bypass hose, removing heat from the center section of the Turbo increases the bearing life.
Comparing MC Express Turbo to the Mr Turbo turbo...The Mr Turbo uses a RayJay F40 (F40 is the compressor wheel), this Turbo is a larger unit (overall demension), plain bearing. The large surface area is used for cooling. Rebuilding a Rayjay is a piece of cake, almost any turbo shop in the country has the parts to repair it. The biggest difference between the MC Express and the Mr Turbo turbochargers is the compressor wheel effienceies. One rating a Turbo is given is the "efficiency rating", this is a simple 1-100% scale. In a perfect world, we could design a Turbo that builds boost without generating heat. BUT, unfortunetly, heat is generated when we build boost (compress the air). So the higher the "efficiency rating" the LESS heat that is generated at a set boost level. Inotherwords, the MC Express Turbo has rating of 78% and the Mr Turbo has a rating of 69%. The MC Express Turbo will produce 9% more HP.
This is were the Intercooler is used. To reduce cost, the Mr Turbo system does not use an intercooler. THe MC Express does, BUT, you have to make the intercooler large enough with a large internal airflow that is not restrictive. Most bike intercoolers are to small, bikes just don't have the frontal area to install one. This is another area that MC Express has done there design homework, they incorporated a large curved intercooler that utilizes the factory RAM air holes. Reduced intake air temperature, increases the O2 level and reduces the killer of turbo bikes, detonation.
Fuel delivery:
Mr Turbo takes advantage of the factory EFI system to it's fullest. They increase fuel pressure to compensate for increased boost level. This is why the MR Turbo system is limited to 7psi of boost or 240hp, the factory EFI system's fuel delivery is max'd out.
MC Express incorporates 4 addtional fuel injectors. These injectors (to my surprise) have the lastest technology, "quadhedrial cone" spray patterns. A fancy term for 4 fine spray mists vs 1 large cone pattern. The advantage is finer spray patterns, better fuel atomization. The injectors are built into the intake manifold, pointing down the into throttle bodies.
MC Express incorporates a pressure activated switch to turn on the secondary (or staged) injectors. A VERY antiquated (old??) way of doing it, but very simple and cost effective.
The manifolds are very well done, although both need more intake pleneum volume. The exhaust manifolds, both could use longer primary tubes, but space on the 'Busa is limited.
Insummary:
The MC Express is a real quality unit, almost a custom made look. The pieces are really heavily constructed, almost overkill.
The Mr Turbo is a simplier unit, tried and true turbo. Least expensive of the bunch.
Biggest problem with both of these systems, you are EXTREMELY limited in the power delivery control. What I'm refering to is controlling the boost and fuel level deliveries. Both of these systems NEED programable EFI, think of a PC II on steriods. Like how about a PC IV!!
I have programmable EFI on my turbobike, I have progressive boost control based on gear and RPM, digital water/methonal injection (reduces detonation), traction and wheelie control, two-step, anti-turbolag, autoshift control, Wide band Lambda closed loop and If I want progressive NO2.
Welcome to the digital age......
Sorry the turbo is not used on a 3000GT. It is a mitsubishi tdo4-16T turbocharger. It is not a hybrid unit either..it is specifically made and designed for VOLVO and SAAB. I disagree with the header lengths too...for streetbikes you want to obtain fast response..what better way to do this than place the turbo as close to the exhaust ports as possible. ALso keeps the oil draining problems out of the picture. As for programmable Pc interface...I have alot of kits to arrive by the end of the year. They are designing a fuel injection unit that will control the additional injectors. This unit will be MAP sensor based as well as rpm based . When finished and they are happy with the results it will be standard on all kits. Fully programmable with pc. The flow rate on the 16t is far greater than a rayjay as well!..good report though!!!
cheers,
seb
GSXR,
Are you using an off-the-shelp EFI system that has wide-range closed loop capability? I think the naturally aspirated Busas desparately need this rather than compromising with the myriad PC-II maps in an effort to "get close" for a particular setup. I would think there's money to be made for someone who could offer a turnkey closed loop system.
You could put the HAHN system in the same section as Mr.Turbo BUT NOTICE THE CAPS!!! The HAhn system uses a very good turbocharger!! I believe the hahn system is the better system over mr turbo. But at this time the mc-xpress system is the top dog..and you pay for it! Anyone know what ever happened to BAD turbosystems...I have had a couple customers inquire about it and then just go with the Mc xpress system because no matter what I did I could not get them any...I mean ZERO information on them. I contacted cyclestuff ..he said the manufaturer or him would get back to me..that was about 1 month ago. It will be interesting to see what happens in the shootout class next year. I have 2 customers that will be racing in the class next year on Mc-xpress turbo busas..Any questions regarding the mc xpress kit you can contact me. I am sure Dennis will be giving a full report on the system once installed and run on the dyno.....Since I have had the opertunity to ride the mcxpress turbo bike while in sweden (although it was only about 10minutes worth) streetability is awesome and the power is insane...the bike I rode made 330 hp.
regards,
seb
Did I just read somewhere that NLR was sending Frank Adams a MX-xpress turbo?
WE ALL know Hahn a BIG jump on R&D with the Gary Wardowski Busa!
Anyway, heres the areas the need to be taken seriously:
gsxr1300<<I have programmable EFI on my turbobike, I have progressive boost control based on gear and RPM, digital water/methonal injection (reduces detonation), traction and wheelie control, two-step, anti-turbolag, autoshift control, Wide band Lambda closed loop and If I want progressive NO2.
Welcome to the digital age......>>
NLR<<As for programmable Pc interface...I have alot of kits to arrive by the end of the year. They are designing a fuel injection unit that will control the additional injectors. This unit will be MAP sensor based as well as rpm based . When finished and they are happy with the results it will be standard on all kits. Fully programmable with pc. The flow rate on the 16t is far greater than a rayjay as well!..>>
~Ding ~Dong...
I think it's the Fed Ex man with a package from Seb?...Be right back! :)
Is Frank getting the turbo itch? Bill is doing a great job with RD on Garys bike. . As for the turbosystem he has..who else has one like it? Can someone call hahn and say I want the same system he has and expect the same 1 on 1 assistance? I dont know...Garys bike I believe is a one off system. Hes making big power and with an aftermarket fuel injection system it takes alot of tuning to get it done..obviously they have the bugs worked out. Now can we compare his system to the system they sell? Sure ..except for the turbocharger and fuel injection system and fuel injectors and ignition system(I think) we can..I think the headers are the same and the pipes are the same. HRC knows how to make power!!!
[This message has been edited by NLR (edited 28 July 2000).]
3000GT VR-4/Stealth Twin Turbo come stock with the Mitsu TD04-9B turbos. The 13G turbo upgrade (9b wheels replaced - same housing) was the first [1992 or so] of a long line of turbo mods/replacements (15g - modified housing, larger Mitsu/Garrett hybrids etc)
I've had a set of each of these since modifying my Stealth TT beginning in 94'.
The 9g/13g setups do spool up very early though.
