jamhulsey
Long story short, the bike sat for several years while I was overseas. Now that I'm back in the US I broke it out and started trying to get it back in shape. It won't start so today I pulled the fuel tank and fuel pump out to see if they were gummed up. They looked pretty clean, but as I was shaking the last few drops of the tank I heard a clank. So I flipped it over and looked in. I found this metal item and I can't figure out where it came from. I'm assuming it's a piece of the fuel pump but I don't see anywhere on the pump that would t would attach. Could this be the culprit for the bike not starting? I'm thinking I may need a new fuel pump, any idea what could have happened and how to fix it?
Picture of the item in my tank is attached.
Additinal info: The bike fires up with starter fluid but only for a couple of seconds. The fuel trickled through the fuel line but doesn't seem to be spraying out of the injectors which I took apart and cleaned, replaced seals, sprayed injector cleaners through with and adapter, and put new screens on. New plugs, new battery, all fuses are good. It isn't throwing codes in dealer mode and only has 4300 miles.
