OB_Mr Bear
I can't answer any of your questions.
BUT, there is more than one way to skin a cat. Someone would have to actually design a, for instance, titanium frame for a Hayabusa, before anyone could put a weight number on it. Titanium has different characteristics than the aluminum alloy used in the stock frame. Titanium is actually a somewhat spongy metal. It tends to compress and bounce back a bit under loading. It is very hard, and has very high tensile strength.
The point is, designing a different frame for the Busa would be no brief task. All the weights and loadings would have to be recorded and calculated, dimensions and wall thicknesses specified, matched up against the specs for the material used.
It is a simple question with a simple answer, but the process of deducing that simple answer is very complex.
