MiBike GPS
dmrowe
Well I had promised back in January that would write up a review on the GPS tracking device commonly known as MiBike and marketed by Talon.  This device is supposed to be able to provide a page to your cell phone if your motorcycle moves or triggers one of three alerts (Low Priority, Medium Priority or High Priority).  The Medium Priority Alert (MPA) functions if there is any movement detected or if the power is disconnected.  The other two alerts (Low & High) function with normally open circuits and can be hooked up to various types of switches, i.e., your alarm, a tilt or reed switch to indicate tampering.  First of all let me say that in theory this is all well and good but unfortunately this device does not even come close to operating in the theoretical realm.  In my humble opinion (and this is only my opinion based on my experience), it is a waste of money only fit for target practice or taking your frustrations out on with a 16 oz. ball peen hammer.  But here is my review for what it is worth pictures included:
1. Initial Assessment – Advertised as the size of a black board eraser.  In fact it is approximately twice the size measuring 5-3/4†long, 3†wide and 1-1/4†thick or about twice the width of a black board eraser with a wt. of approx. 318 gr. or just over 11 oz. (it’s big).  This particular device had sat so long on the shelf that I had to send it to Teydo (the provider of the GPS service) to have the SIM card updated.
2. Installation – Couldn’t find any place to ‘bury’ it on the bike, won’t fit under the nose, side or tail fairing.  The only place this would fit is in the boot.  When I contacted the owner of Talon regarding installation locations I was told he had never installed one on a Busa and that he himself did not have one on his motorcycle.  I probably should have asked if he had ever installed one period!  During the installation process is when I found out that this device had to be installed in a specific manner.  The blue node of the device has to be pointing upward and in a location where it could transmit & receive a signal.  This was accomplished by trial and error after activation ($100) and the purchase of a tracking ‘bundle’ ($42) through Teydo via Locationxs.com
3.  Customer Support – You can’t talk to a live person, you get your technical questions answered by live chat or emails.  Being on the West Coast and only home on weekends this proved impossible and resulted in the exchange of at least 75-80 emails.  Now don’t get me wrong they try, but they just don’t get the job done.
4. Operation – Now according the operating parameters I wired in a mercury tilt switch and a cut off switch (to disable the tilt switch) into the HPA circuit so that if the bike was tilted upright it would close the circuit and send me an alert.  This function never worked and after 3 months of trying I finally find out that the selection of notifications is for email only and even then I never got one alert to my email.  The device when moving will send you continuing alerts based on your selection of the time frame of reports ranging from every 10-15 min. to 10 hrs.  This never worked either as I could never select anything other that 10-15 min.  This has the potential of being very, very expensive at $.50 an alert.  You also have the option of selecting ‘battery save mode on’ or ‘battery save mode off’ so you can ping the unit to get its current location, could never get this to work although I was able to get current location, even when it came back as ‘location unknown’.  This occurred many times when I was riding the bike, I was told this was a software glitch.
5.  Results & Conclusion – MiBike is a POS, save your money.  Yeah I feel a lot lighter in the wallet but I chose to be the guinea pig so I am not going to complain.  Although when I think about I could have spent the money on a $500 an hour hooker and gotten some enjoyment out of getting screwed.
Now there are other GPS products out there that may function in the manner desired, i.e., provide an immediate alert if your bike is lifted and allow you to track it via your PC through a GPS website so you can get it back in one piece or even better notify the police that you are about to smoke a couple bike thieves and to come and collect them before they wind up in the compost heap.
The Device
In order to allow functionality you have to solder various resistors in to the sensor (yellow) wire:
The sensor wire with resistors wired in:
Disable (cut out) switch for the tilt swith on the HPA circuit. Not shown as I forgot to wire it in before I finished this step!
The gismo as it goes in, you have to allow the yellow wire to hang freely somewhere:
Tilt switch:
This mounting is incorrect, I had to relocate it so it was between the metal brace and the back wall of the boot.
I have taken this thing in and out so many times, following the tech's instructions to 'reset' which required removal, opening it up and shorting out between a couple of pins to restore default perameters that I am an expert in disassembly and removal of the tail section. Unfortunately after about 8 times you tend to get pissed off! I hope this information helps someone and they avoid the grief, aggrevation and expense that I have gone through. Now I am ready for a drink. Bombay Saphire on the rocks please!
(05BusaLe @ May 25 2007,20:18) How bout this, I will be getting one in the next few weeks,
http://www.gpsonsale.com/vehicle....SMS.htm
Look at the costs involved, purchase price, activation for 1 yr. and then the tracking bundle! For what these folks stand to make they should give the darn thing to you. The draw back I see with this is that it depends on an internal power source that you would have to monitor and then does it give you alerts if it moves or do you just track it via your PC? The whole function I was looking for was the ability to be alerted if the bike moved and then to track to see if it really was moving and then to intercept it or notify the police. The area that I live in has excellent coverage for LoJack and they have come out with a new enhanced early warning system. Now it is not GPS based but it will alert me to the fact that my bike is moving so I can notify the cops it has been stolen and hopefully recover it before it gets wrecked. I am definetly gun shy on GPS's, they would have to give it to me to or give me a 30 money back guarantee. I think they are a rip off for the pricing, but that is just my frustrated opinion!
It uses a geo-fence set up you set it and if it moves from that area it alerts you via text message and email. There is a plan I found from the company that is $140 per year and lets you track it on line! If it works I like it better then the $2800 per year quote I was given for full coverage.
David,
Before you expend that much money take a look at LoJack. In the area that I live in they give coverage for all of the surrounding areas (except Mexico). They have an enhanced system that gives you an advance alert that they bike has moved. It is not GPS based, but it lets you know that the bike has moved and you can verify that it has been stolen immediately rather than coming out and looking for it the next day. I am very leary of the claims and costs of these GPS systems. Jeezus, after 20 oz. of Bombay Saphire Martini's I can barely type. I am glad I have decided to put this whole thing behind me. Save yourself the aggrivation and expense with these guys unless they are willing to give you the system with a 30 day money back guarantee! Goodnight all....I'm toasted!
hey man, sorry to hear this got so out of control-hope the LoJack system works better for you.
I am working out a sponsorship with an new Motorcycle Alarm manufacturer, Cycleprotect
I should be picking up a unit in June for installation/testing (i.e: stealing my own bike to see if it works) on my bike, I'll try to get a review up here as fast as possible, and I already talked to the owner/operator about a possible GB and he's very agreeable, still talking about pricing but it looks like a great deal for the $$...will know more in about 3 weeks
until then...chain your dog to the Busa at night!
Big D,
Get one, install it and let us know how it works. The whole thing with the GeoFence with MiBike is that would not let me select the option and then it was only email notification. I want something that will ring my cell phone and let me know something is afoot. Cycleprotect looks and sounds like they have the right idea, now if they can transfer it into true functionality they will have a winner.
