OB_Billy V
Bluebusa,I recently installed the full system with carbon can on my 99.The pipe came from my friends bike on the east coast who had a slide on the left side,the pipe was probable one of the very first pipes made for the busa.After I tryed a rough fit to the bike I saw the number #2 down pipe was going to make contact with the oil cooler.I called micron and they sent me some instructions for the pipe.The rep said some of the early pipes were tight fits.So I decided to cut 1/4 to 7/16 inch off the #2 down pipe and it fit with 3/16 of an inch clearance between the #2 pipe and the oil cooler.I also used the spacer for the oil cooler line,and two washers between the the the oil cooler and radiator support bolt where the two come together on the left side to give me some more clearance for the #2 down pipe.As per instructions the whole system fits real close to the sump,but stress relieves after you run it awhile.
