Front brake calipers, I recommend a 6 point 12mm socket. Again, you may want to apply a little tap (impact) to assist in the removal process. Once you accompolish those bolts, the only ones you really get to look forward to would be the brake rotor bolts, but that should be a little while until you need to replace those...
