Please don’t wet your pants, but you can cry!!!
Obviously written by a guy, so forgive his somewhat explicit expressions....
A bit gross, but still humorous...
Thought y'all should read this in case you're thinking of installing an
electric fence!
We have the standard 6ft. fence in the backyard, and a few months ago, I
heard about burglaries increasing dramatically in the entire city.
To make sure this never happened to me, I got an electric fence and ran a
single wire along the top of the fence. Actually, I got the biggest
cattle charger Tractor Supply had, made for 26 miles of fence.
I then used an 8 ft. long ground round, drove 7.5 feet into the ground. The
ground rod is the key, with the more you have in the ground, the
better the fence works.
One day I'm mowing the back yard with my cheapo Walmart 6hp bigwheel
pushmower. The hot wire is broken and laying out in the yard. I knew for
a fact that I unplugged the charger. I pushed the mower around the wire and
reached down to grab it, to throw it out of the way. It seems as
though I hadn't remembered to unplug it after all.
Now I'm standing there, I've got the running lawnmower in my right hand and
the 1.7 gigavolt fencewire in the other hand. Keep in mind the
charger is about the size of a marine battery and has a picture of an upside
down cow on fire on the cover.
Time stood still. The first thing I notice is my balls trying to climb up
the front side of my body. My ears curled downwards and I could feel
the lawnmower ignition firing in the backside of my brain..
Every time that Briggs & Stratton rolled over, I could feel the spark in my
head. I was literally at one with the engine.
It seems as though the fence charger and the POS lawnmower were fighting
over who would control my electrical impulses..
Science says you cannot crap, pee, and come at the same time. I beg to
differ. Not only did I do all three at once, but my bowels emptied 3
different times in less than half of a second. It was a Matrix kind of bowel
movement, where time is creeping along and you're all leaned back
and BAM BAM BAM you just crap your pants 3 times. It seemed like there were
minutes in between but in reality it was so close together it was
like exhaust pulses from a big block Chevy turning 8 grand.
At this point I'm about 30 minutes (maybe 2 seconds) into holding onto the
fence wire. My hand is wrapped around the wire palm down so I can't
let go. I grew up on a farm so I know all about electric fences... but Dad
always had those POS chargers made by International or whoever that
were like 9 volts and just kinda tickled. This I could not let go of.
The 8 foot long ground rod is now accepting signals from me through the
permadamp Ark-La-Tex river bottom soil. At this point I'm thinking I'm
going to have to just man up and take it, until the lawnmower runs out of
gas.
Damn!,' I think, as I remember I just filled the tank!
Now the lawnmower is starting to run rough. It has settled into a loping run
pattern as if it had some kind of big lawnmower race cam in it.
Covered in poop, pee, jizz, and with my balls on my chest I think 'Oh God,
please die... pleeeeze die'. But nooooo, it settles into the rough
jumpy cam idle nicely and remains there, like a big bore roller cam EFI
motor waiting for the go command from its owner's right foot.
So here I am in the middle of July, 104 degrees, 80% humidity, standing in
my own backyard, begging God to kill me. God did not take me that day... he
left me there covered in my own fluids to writhe in the misery my own
stupidity had created...
I honestly don't know how I got loose from the wire....I woke up laying on
the ground hours later. The lawnmower was beside me, out of gas. It
was later on in the day and I was sunburned. There were two large dead grass
spots where I had been standing, and then another long skinny dead spot were
the wire had layed while I was on the ground still holding on to it. I
assume I finally had a seizure and in the resulting thrashing
had somehow let go of the wire. Upon waking from my electrically induced
sleep I realized a few things.
1- Three of my teeth seem to have melted.
2- I now have cramps in the bottoms of my feet and my right butt cheek (not
the left, just the right).
3- Poop, pee, and semen when all mixed together, do not smell as bad as you
might think.
4- My left eye will not open.
5- My right eye will not close.
6- The lawnmower runs like a sumna***** now. Seriously! I think our little
session cleared out some carbon fouling or something, because it
was better than new after that.
7- My balls are still smaller than average yet they are almost a foot long
8- I can turn on the TV in the gameroom by farting while thinking of the
number 4 (still dont understand this?)
That day changed my life. I now have a newfound respect for things. I
appreciate the little things more, and now I always triple check to make
sure the fence is unplugged before I mow.
The good news, is that if a burglar does try to come over the fence, I can
clearly visualize what my security system will do to him, and THAT
gives me a warm and fuzzy feeling all over, which also reminds me to triple check before I mow.
electric fence!
gas.
might think.
