MORE GEARING ?'S
ToXSicK RoCKeT
Hey there speed freaks
im 6' 260+/- a pound or two
ya ya i know DIET FAT BOY, anyways can someone give me some help on a good starting point on gearing an 08 busa for 1/4 and a little street raceing......i mean riding? i will have broks cluth mod, slammed, A/H exhaust, pc, brocks map, 6-10 over mac arm(prob set up at 6" over), but am clueless on wear to start the gearing headache? thx
I'd start with a 17/45 then it would be an easy swap to a 18 on the street.
That should get you in the ballpark (it will be close to the common 16/42)
Is this formula correct? For every 4 teeth in the rear is like changing 1 tooth in the front? thx for the replys so far
Man i cant wait for all my goodies to get here(A/H, PC, MAC ARM, CLUTCH MOD)...... I'll be a busy man
1 down on the front is like going 3 up on the rear...
I'm a big guy like you 250 suited I run 17 50 and it perfect.
You can't 60 foot with the gearing these guy run as you can see they are not drag racers like we are. The 08 doesn't have enought hp to 60 foot us big guys so we need gearing. I can now 1.5? 60 foot and have 6.2's in the 1/8 mile at 114 this is at an elavation of about 3500 ft up in the mountains. So don't be scared to gear your bike.
If all else fails go to the track and count the teeth on the fast guys bikes that are as big as you and you'll see it aint the crap these guys are telling yoy.
Re: MORE GEARING ?'S
2007 Busa and Im 5'8 and 210 suited. Was running 17/43t then changed to 17/45t...still have 1.7 for best 60ft. With the 45t and the ultra clutch mod I could launch much better with NO bog. Need more seat time to play with launching R's.
you dont want to go to a 18t front sprocket unless you plan on doingtop end runs. I would go like 16/42 but its going to depend on your rigind style
Thx bro, thats what i wanted......the no BULL$H!T answer from a guy my size:thumbsup: I could careless about freeway riding, twistie, and gas milage, i want to be geared for best ET times......WHAT THE BUSA WAS MADE FOR......imo :beerchug:
If you want the best et, run 16/45 run it in 5 gears. your speed will be down a bit, but it will help et the most. i ran it at 230 on a 02 best of 1.51 9.79 139mph should be about the same or better 4 u on a 08 with the extra weight
re read the post
17/45 for racing
18/45 for the street
The "typical" 17/43 is 2.53..(18/45 is 2.50) you then get the an easy to change setup that you can race or take a Sunday ride on..
Looks like a nice compromise to me...
GEN1 and Gen2
Gear ratio:
1 - 2.615
2 - 1.937
3 - 1.526
4 - 1.285
5 - 1.136
6 - 1.043
Here is a nice reference to Gear/vs/MPH
GEAR RATIO = SPEED IN GEARS
Gearing 1st 2nd 3rd 4th 5th 6th
16/39 77 104 132 157 178 194
16/40 75 101 129 153 173 189
16/41 73 99 126 150 169 184
16/42 72 97 123 146 165 180
16/43 70 95 120 143 161 176
17/39 82 111 141 167 189 206
17/40 80 108 137 163 184 201
17/41 78 105 134 159 180 196
17/42 76 103 131 155 176 191
17/43 74 100 128 152 171 187
18/39 87 117 149 177 200 218
18/40 85 114 145 173 195 212
18/41 83 112 142 168 190 207
18/42 81 109 138 164 186 202
18/43 79 106 135 161 182 198
19/39 92 124 157 187 211 230
19/40 89 121 153 182 206 224
19/41 87 118 150 178 201 219
19/42 85 115 146 173 196 214
19/43 83 112 143 170 192 209
Thx Fella's for ALL THE HELP......I went to 17/45, Still does not feel like enough gear! Was thinking of dropping it another -1 on the counter? Anyone know of or have heard of any problems with running -2 (16) on the 08's? Any problems to look out for with chain?
BTW, i am running a mac alumi pro arm(dont think that makes a difference but.....) Thx in advance :beerchug:
