more help pleeeease :-)
edsmini
hi guys,
well, im stuck again, a couple of the plugs have got me baffled. the connector on the left i beleive to be for the speed sensor?
i assume the picture below is for the oil pressure sensor and rear brake pedal switch?
much appreciated for any help :-)
Ed
The one on the left IS your speed sensor...... The one on the right might be for fuel? Do I see an alternator in that top pic?
yeh i have fitted an alternator, ive searched the net and i think the one on the right is for a pair valve solenoid? does that sound correct? and the wire beside the oil sensor wire seems to be for a side stand relay and indicator? this thing has got my head pickled :-(
Ed
for a car im afraid,
im scared that i get slagged on here for taking a hayabusa to pieces for my project ???
Ed
well guys, i managed to find a wiring diagram on the net and i printed it off. and as luck would have it, when it printed out over 16 separate pages, i stuck them all together on a large piece of cardboard, so i now have a drawing that is 30 inches x 24 inches :lol: so that should be he end of the stupid questions i keep asking.
thanks again to all those who have helped with my questions :-)
i will have more questions relating to TRE sensors etc :-)
Ed
No slagging from folks here as long as we get a chance to drive it......
what will happen if i remove the pair valve? will i have to fit a resistor between the 2 wires? the o2 sensor requires a resistor of around 320 ohms but im not sure which 2 wires to bridge with the resistor?
any help appreciated
Ed
