Mototeck undertail - Brake Light Bulb
mvanlone
I have searched this site and I have noticed that the Mototeck undertails sometimes the bulbs for the brake lights flicker and stuff like that and there is something wrong with them. Well mine flickers and can someone help me with which bulb number I need to replace it. I have the upgraded Leds that are more of them and brighter. Can someone tell me if these are the bulbs that I need to replace the brake bulbs? This link here: http://www.ironpony.com/ironpon....RODUCTS
Pic here Part number: 30045
Looks like an 1157 bulb. 1156 is for stuff like running lights only and since you have a brake and running light you will need a 1157 bulb. Part number 1157-R24 is a good choice at this sight. I actually own two of these LED bulbs with no issues. Or can take your chances on Ebay. Buy a set to have two of the same lights. Don't go buying tower style LED bulb unless you sure you will have enough room for them. The one I gave part number isn't a tower type,but is a wide angle type(led's on side). The pic you have only shows the front end. Does it connect like a regular bulb would on a stock tail light? If it doesn't then the one you have in pic is incorrect. Have doubts post a pic of your actual bulb off your bike.
Here is a bunch of LED BULBS to choose from.
Hope this answers your question.
1157 pictured here
https://www.superbrightleds.com
