MPH with Gear Changes
Corso1
All-
I haven't the cash to get a Speedohealer right now. I was wandering if anyone might happen to know what the actual speed vs indicated is on a Busa once the gearing is changed to 16/42.
Any ideas? All replies are appreciated.
Thanks-
Corso
With stock gears the speedo is off about 7%....16/42 and your off by about 18%. Tire wear can also throw it off a little more. With it off 18%.....100MPH indicated would actually be 82MPH
I might be interested in the speedo healer group buy too. I don't like guessing my speed.
All-
Thanks-
Corso
You will be off by about 14%  Stock is off by 7%  18/40 is off by about 2% 19/41 is right on the money.
<!--EDIT|Ninja Eater
Reason for Edit: None given...|1115446803 -->
Thanks everyone.
At least I will have some idea where to troll at when the troopers are out in force.
KS- Please do let me know about the group buy. I'm definately in.
Thanks again.
Corso
You will be off by about 14%  Stock is off by 7%  18/40 is off by about 2% 19/41 is right on the money.[/quote][/QUOTE]
I thought 18/40 was much accurate...... saw that somewhere at the other forum.
with 16/42, everything else stock:(ratio/mph) 1st gear- 10.956/ 68.11, 2nd gear- 8.115/91.94, 3rd gear-6.393/116.71, 4th gear- 5.384/138.60, 5th gear- 4.759/156.78, 6th gear- 4.370/170.75....
with 17/40 (stock)- 1st gear- 9.820/75.98, 2nd gear- 7.274/102.58, 3rd gear- 5.731/130.20, 4th gear- 4.826/154.62, 5th gear- 4.266/174.90, 6th gear- 3.917/186. All at 10,250 rpm. Good luck keeping the front end down
<!--EDIT|moondog
Reason for Edit: None given...|1115520965 -->
