Krieg
Wanted to find out if anyone was using a Mr. Turbo kit? If so what are your impressions? Looks like a pretty complete kit. What do you think?
http://www.mrturbo.com/
First talk to NLR link is on the main post page. Seb was working on a basic kit. Hs quality and service or great. If he is not ready with the basic kit then I would go with a couple of others. Check with NLR first, if he is not ready I will give you a list. Depends when you wnat to do the turbo also.Great, I will look forward to hearing your update Dano.
N.E. is there a more modern kit you would recomend that is in a similiar price range?
Basucally it is a mitz 16T large. Basic Same set up that the Eclipse & EV0 (larger compressor) has. Running T-rex full pump with a Cartec rising rate regulator. Cstom machine full rail with larger injectors and a blow off valve. Will give me 310hp all day on the road at any gear all the way from 3,000rpm to the top. Many many sstems that will get more, but I am happy with what works for me.its also important to remember that peak horsepower is not the most important factor unless your just bragging. i come from turbo cars and there are some things ive found that you guys may or may not know. first, be more interested in having the right trim setup for your turbo so you get more power throughout the rpms, anyone can spike 400hp but can you do it fro more than 300 rpm. second, dual ball bearing turbos have there advantages but for most people standard bearing turbos are more affordable, more rebuildable and have many more customizing options. im not an authority on how bikes get the oil to and more importantly from the turbos so that could change my point. ninja eater and other turbo guys can help with that. ninja, what tubro and trim package(compressor, turbine housings and wheels are you running?unless its secret![]()
