And I thought I was done spending money.You need the multi-function hub and the ignition module,then your set.
Spray bars just got here.
There are a lot of options with that hub.I'm not going to spray mine for now, but I intend to fine tune the map in each gear. I'm also going to build a map that is detuned for first gear in the upper TPS range midrange up. This should allow me to launch harder and more consistently giving me more room for operator error. Done right with a two step"¦ I might even be able to almost throw away the clutch and ride it out"¦.even with my stock wheelbase. I might have to use an ignition module and tuning to get to that point however.
Professor, I can mod a gps sensor to only allow spray in 2nd-6th gear if you need. I would have to wire it up like a TRE when done. Done it for a number of guys who are liking the results.I'm not going to spray mine for now, but I intend to fine tune the map in each gear. I'm also going to build a map that is detuned for first gear in the upper TPS range midrange up. This should allow me to launch harder and more consistently giving me more room for operator error. Done right with a two step"¦ I might even be able to almost throw away the clutch and ride it out"¦.even with my stock wheelbase. I might have to use an ignition module and tuning to get to that point however.
I'm not sure, but if not it would be fairly easy to uses a throttle position switch to do it. I've actually got one just for that purpose. I was going to use it to disable my autoshift if necessary. I'm going through the lights at about 10,100 so I haven't had to use it.There are a lot of options with that hub.
I wonder if that relay trigger can be set for specific gears ?
That is always another option!Professor, I can mod a gps sensor to only allow spray in 2nd-6th gear if you need. I would have to wire it up like a TRE when done. Done it for a number of guys who are liking the results.I'm not going to spray mine for now, but I intend to fine tune the map in each gear. I'm also going to build a map that is detuned for first gear in the upper TPS range midrange up. This should allow me to launch harder and more consistently giving me more room for operator error. Done right with a two step"¦ I might even be able to almost throw away the clutch and ride it out"¦.even with my stock wheelbase. I might have to use an ignition module and tuning to get to that point however.
[/Quote]Its inexpensive and has worked very well for others. It would disable any other gear based things you might be able to do with the hub though as I have to wire the sensor up like a TRE in order to ground a relay with it.
View attachment 1592652 </span>
