fritch1969
after shutting the bike off the gas tank builds up pressure and whistles, did anyone ever notice this with their bike ?
come on now that means its tea time . Everyone knows that . Jolly good ole chap(Revvv @ Feb. 26 2007,00) I feel the need to bring back the topic of the annoying whistle. Is there a way to stop it? Is there a vent clogged somewhere?
This has to be the most irritating sound I have found outside of a blown motor.
I rode the bike in the cool evening air for it's first ride since my ownership. When I got back to the garage I let the bike run while I listened for any abnormal noises. I'm thinking I have a noisy clutch that Busas are known for. I thought I had a bearing going outThat noise calms down a little when the clutch is pulled, but it is a hydro clutch (A toy I know little about).
After I satisfied myself to some degree with the engine I shut the bike down only to hear THE WHISTLE BLOWING. It went on for what seemed to be forever. I wanted to see just how long it carried on, but I couldn't stand the noise and finally popped the cap.
The tank had pressure. It literally sucked air when I lifted the cap.
OK - enough with the book - What can I do?
Help me
Bike is a 2003(06BUSA @ Feb. 25 2007,22) People may not believe it, but there is a winter grade gasoline. It has a higher vapor pressure for easier starting. It also means it vaporizes easier. More heat = more pressure.
Sorry I dont have a better answer.
New bike? If used check to see if the insulating pad is on the bottom of the tank. That pad stops heat tranfer from the motor to the tank.
Are you sure the vent tubes aren't clogged?
