I just use two threaded rods one in the axle one in the swing arm pivot. It's not because I think the Gillis chain adjusters are inaccurate, it's just easier to do standing up. I can easily get to within less than one MM using a standard tape measure. it'd not my idea I just wasn't willing to spend money on the fancy set up with the adjustable cones.
This assumes your frame is straight.. If your frame is bent you have bigger problems that a chain alignment can fix.
The restaurant aluminum sheet pan under the bike is handy for catching chain lube kerosene etc etc....
cheers
ken
cheers
ken
