I have something similar on my garden tractor....sure makes oil changes easy and simple...I love my fumoto valve I use on my Tacoma. Stick a hose on the end, run to a container, pull the plastic handle lock and open the valve. Let it drain while you do everything else and then close and replace the plastic lock and done. I don’t change oil as often on the busa to feel the need to install one of those.
I’m not sure why they complicate oil changes on lawn equipment. My cousin’s “deer” was kind of a PITA too when I used to do the maintenance for her. On the Tacoma, I run an aftermarket skid plate that goes from the lower radiator support to the transmission crossmember and the fumoto valve makes it easy for me to just stick a hose through the hole they put on the plate and then reach from the side to connect the hose and open the valve. I’m not an off-roader but the undercarriage protection helps me sleep better at night since catalytic converter theft is real down here. Just ask @c10 about the poor lady at the hotel he stayed when he was down here.I have something similar on my garden tractor....sure makes oil changes easy and simple...
I change the oil on a tractor one of the seniors has and it is a PITA without this...
I was servicing my friend's Lawn Boy push mower and it has no drain plug...the manual says to take the filler tube out and tip it on it's side to drain the oil....all I could picture was a big mess...I use my Mitivac on itI’m not sure why they complicate oil changes on lawn equipment. My cousin’s “deer” was kind of a PITA too when I used to do the maintenance for her. On the Tacoma, I run an aftermarket skid plate that goes from the lower radiator support to the transmission crossmember and the fumoto valve makes it easy for me to just stick a hose through the hole they put on the plate and then reach from the side to connect the hose and open the valve. I’m not an off-roader but the undercarriage protection helps me sleep better at night since catalytic converter theft is real down here. Just ask @c10 about the poor lady at the hotel he stayed when he was down here.
That engineer deserves to be forced to stand behind the owner so he gets elbowed in the jewels every time the owner pulls the string to start the mower for such design.I was servicing my friend's Lawn Boy push mower and it has no drain plug...the manual says to take the filler tube out and tip it on it's side to drain the oil....all I could picture was a big mess...I use my Mitivac on it
It sure had me scratching my head.....That engineer deserves to be forced to stand behind the owner so he gets elbowed in the jewels every time the owner pulls the string to start the mower for such design.
That's exactly what happened. When we design a building we check to make sure it can be built with collision detection. We even have service zones built into the models of valves and equipment so a conflict will show up if something can't be accessed or fit. A lot of stuff gets designed and people assume it can be serviced. They let the customer discover the puzzle created by how it was designed.....it was almost as if changing the oil was an afterthought.
A sad reality.....That's exactly what happened. When we design a building we check to make sure it can be built with collision detection. We even have service zones built into the models of valves and equipment so a conflict will show up if something can't be accessed or fit. A lot of stuff gets designed and people assume it can be serviced. They let the customer discover the puzzle created by how it was designed.
lmao. I’m the same way… also would look at every driveway and be thinking “I’m going to rip that valve off… this is it… this is the time it comes off”Most new cars you have to remove a half dozen panels and parts just to get the filter off.
This valve for bikes looks nice but my panic driven ocd would probably prevent me from feeling comfy with it. ‘They are out to drain your oil!’ would be the constant voice in my head right after ‘They know you have an easy drain valve on your bike’ came out.
