After looking at the price of pro tool to do this job I decided to do it myself.
I know the sting method can be used but I wanted to do it different.
I did use the sting methond to verify my results.
Home Depot boud I went. Purchased different size rubber stoppers, two metal rulers, two 1/4" steel rods.
I already had some aluminum right angle (from license plate install)
Plug holes on both sides and drill in the center.
Do the same for the rear axle.
Put rods thru stoppers (silcone grease makes them slide easier)
Take rulers with right angle brackets riveted to.
Hooked up the string method.
Verify distance on front and rear tires to sting.
Front left
Front right
Rear left
Rear right
Now I looked at the rulers on top of the rods
right side
left side
Done.
Now to work on the strips. The PP 2CTs are taking a break.
Front left
Front right
Rear left
Rear right
right side
left side
Done.
