My shortbike solution
chevelle
I like to spray from 2nd gear. On a short w/b stock ride height bike that really limits how much you can spray. Two smaller shots solve the problem pretty well. Very flexible,use the small shot the bigger shot or both together. The map switch makes it possible.
Cut down Tiger panel,pressure gauge,switch's for the bottle heater and 2nd stage,map switch is off to the right.
Angled 2 hole Rice ya style plate,12'' line for the 1st stage,8'' for the 2nd.
Solinoids etc.
Button for the 2nd stage.
I have trouble spraying 40hp in second on a 4 inch stretched bike. Besse comes right up on a good track. I can't imaging it on a short bike.
Thanks jc....plenty of room on that panel for a stage 3 switch. Yes Dynotune solenoids,with some high tech goop on 1 of them to stop a slow leak.
