With the Clear Alternatives kit, there is a gapping hole in the back of the assembly for the Turn Signal wires to run through.
1. Here is my fix, I took the bulb socket that should go in the hole and pulled the wires out of it.
2. You have push the wires up through the socket and then cut them. Then you can pull them out.
3. Run the Turn signal wires from the clear alternatives kit through the existing holes. I believe you could tie a leader to the signal wires to pull them through, but I had to disassembly the socket.
4. Once you have run the wires through the socket you are done, just twist the socket in the taillight assembly and you have a seal as good as the factory.
Sorry I don't have step by step pics (didn't occur to me at the time) but this is the finished product.
http://i19.photobucket.com/albums/b182/hwan7485/DSCF0029.jpg
http://i19.photobucket.com/albums/b182/hwan7485/DSCF0026.jpg
http://i19.photobucket.com/albums/b182/hwan7485/DSCF0027.jpg
http://i19.photobucket.com/albums/b182/hwan7485/DSCF0025.jpg
