hi all
i have a friend that is adament about buying me a NOs kit. They want to know if they should get me the dry or wet kit. I have heard the dry are pretty simple to set up. what should be my concerns about a wet kit?
thanks for your help
why not? have a purge on mine,its just to get the air out of the line and it looks pretty cool tooYou don't purge dry systems do ya??
How much are you spraying? Dang, I hope mine don't flip!why not? have a purge on mine,its just to get the air out of the line and it looks pretty cool tooYou don't purge dry systems do ya??
I have a dry shot set up on a WOT switch with dely and progressive spray,mine is set at 2 sec at 80% ..which means it starts spraying at 80% and is at 100% within 2 sec,,this is so i dont flip her over in 1st or 2nd gear.cant imagine wanting anything more!!
is the purge easy to do yourselfA purge can be used in a wet or dry system. It's instaled in the nitrous line befor the nitrous solenoid. The purpose is to purge the system of gas and liquid nitrous at the solenoid. The purge is normaly activated shortly before the activation of your nitrous system. It gives the system a "harder hit". When you've got gas in the line it's starts out as a softer hit until it's flowing liquid nitrous. You could "soften" the hit even more by having longer lines.
it's the same instal process no matter what.is the purge easy to do yourselfA purge can be used in a wet or dry system. It's instaled in the nitrous line befor the nitrous solenoid. The purpose is to purge the system of gas and liquid nitrous at the solenoid. The purge is normaly activated shortly before the activation of your nitrous system. It gives the system a "harder hit". When you've got gas in the line it's starts out as a softer hit until it's flowing liquid nitrous. You could "soften" the hit even more by having longer lines.
what if someone just wanted dry for the purge..is it any cheaper or easier
All it is is an additional solenoid with a line vented to the atmosphere. When you hit the purge button (momentary switch) the solenoid opens and nitrous is able to escape the system into the air until you release the button. For optimum performance, the purge valve should be mounted as close to the system nitrous solenoid as possible, upstream of the solenoid.
thanks guys for all ur help. i called today and told her a dry kit.
honestly bro,I dont ever use it,I dont have a need,the bike is quick enough for me.the NOS was on there when i bought the bike and i was told by the guy i bought it from who builds race bikes for a living,that i had 2 sec to get it out of 1st gear or she was gonna flip(also have an air shifter),i have used it a few times but i was alrady rolling down the road at 90mph in 4th gear,got from 90 to 160 in like 2 seconds though.I put the purge kit on just for show.I dont see a need for NOS unless your going to the track.AM -->How much are you spraying? Dang, I hope mine don't flip!DEVLDOG @ Feb. 06 2008 said:1287329[/ATTACH] AM]
Yes you do, on cars at leastYou don't purge dry systems do ya??
