I'm trying to install the +1 links/dogbones and the bottom bolt came off without a problem, but the higher one is not coming off so I'm in the middle of trying to grind/cut that puppy off so I'm going to need new ones. What size bolt and nut are these? Also should I use some loctite when installing?
P.S. Nothing was going to get it off other than maybe a blow torch...and I had the weight off the rear suspension using the steel rod and jack stands.
