hitchedup21
Hey Everyone
Need a little help here doing some troubleshooting… I have a 1999 Busa that I am working on for a friend. Something happened with the transmission that caused it to brake the case, so in lieu of trying to fix it he just bought a complete replacement engine. The replacement engine was bought at a reliable salvage company and we were told the engine ran. The (replacement) new engine is a 2007 model. I completed installing the engine and attempted to start it but it will not start. The engine turns over without issue and from time to time I can get a pop out of the exhaust like it wants to start. I have also encountered some blow back out of the air box. I have checked for spark at all cylinders and they all have good spark. When I pull the plugs after attempting to start the engine they are wet with fuel and the fuel pump is running as it should. I have went back over my installation and checked everything that I worked on checking for errors (Harness plugs not completely together & what not) and all of that checks out fine. With some of the obvious signs it leads me to believe that it seems like the timing may be off??? Not sure how that could have happened if the engine ran and was not taken apart. Also any thought that the computer for the 99 bike doesn’t work with a 07 engine? I thought I may have read somewhere about there being a different ignition system in the 99-00 bikes then in the 01+ bikes? Any help would be great thanks
