need good turbo for low cost
hayabusa05
i have a 05 busa and need more power but nitros kills the motor so i want a turbo but not a whole lot of cash whats the best for low cost
nitrous will kill the motor just as bad as a turbo actualy nitrous will prob kill a motor less if the turbo isnt tuned properly...
either one needs to be tuned correctly and on both you dont want to go cheap...being  "cheap" will kill your motor b4 anything else
if either one is tuned properly the motor will last a good long time and run smooth.
and for price ranges on turbos do a search my friend
<!--EDIT|SPEEDEMON
Reason for Edit: None given...|1138585335 -->
"low cost turbo"
doesnt exist unless its used,then there will almost always pieces missing.
get a new Velocity or ghetto,you'll be glad you did,if you were here,I'd let you try mine,insane ride!
low cost turbo = massive engine destruction from what I've seen here on the board.
8606 dennison ave
cleveland ohio
around $5k installed for 250-280rwhp with internally stock motor.
If you want to do a low cost Turbo save up some more money. Even a lower cost system will cost to get it set and tunned. If you don't have it tunned by a pro you coyuld be looking at a new motor. If you are real good with mechs do the install and then have it Dyno tunned by a pro.
