i just took mine off yesterday..
loosened the six allen bolts for teh plastic.. loosened the 4 allen botls for teh brake caliper.. 2 on each side..
then loosened the left side (if you are infront of the bike) pinch bolts.. do not LOOSEN the right side.. then use a tool to unloosen the axle bolt.. then you can loosen the left side. then pop out the wheel rod (whatever its called.) when tightenting same thing but tighten left side first then put start tightening right side
good luck
