Is there any trick to getting the sprocket back onto the wheel after you put new rubbers in. I know there supposed to be tight but damn. Ive tried standing on the sprocket and everthing..........any ideas?
try wd-40 on the cushions, it worked for me... just be careful when applying pressure to the sproket area. I used 2 six inch 2x4 and laid the wheel across them and muscle sproket on...Hope that helps
Use KY, no joke.....water soluble and will not hurt the rubber, the piece will slide right in with a little wiggling. Got to be careful about using petro based lubes on rubber, may be the reason the cush blocks are going away so quickly...
