Busa-Tamer
Hello Busa Lovers
I'm having a issue with my bike not starting. First off I have a 1999 hayabusa I got a good deal on a motor 06 with 5,000 miles on it. I've installed the engine knowing mine was a 16 bit ECU. So I used my magneto, and rotor from the old engine. I've used a multimeter and checked all points from magneto to ecu all seem to be showing within acceptable range are on the point any number specified in the manual. every time I go to crank her up she want start and I get a F12 code. I've read post of the 16 bit and 32 bit ECU. From my understanding if rotor,wire harness, and ECU is all the same 32 or 16 there shouldn't be a problem. What else can I check or change to eliminate this issue and start my baby up PLEASE HELP
THANKS in ADVANCE
THANKS in ADVANCE
