I am looking to get my busa at around 190-200 hp. What can you recommend I do? I keep hearing about 1397 kit or 1401 kits... Is this stoking out the engine to this displacement and adding pistons and hot cam?
i am nt sure if am able to advise u...
i been reading up on the hp gain...
u have a few choice here.
1. "stoker" kit using 08 crank that will give a u lift of 2mm tog with 08 piston giving u 12.3CR.
2. stock bore aftermarket cam with correct correct deg and u noe ur work tog with a 13.1CR piston
3. big bore kit of 1397 and u can either play with the piston or crank or cam (cylinder wall will be thinner)
4. turbo "plug and play" kit stage 1 shld get u easily to 200+ hp with pump gas, no need to do any crank, cam or piston.
these are my option... i dun noe which one also
haha
