I was wanting to put a kanji decal on my hump..does anyone have pics? What size decal would look good? This is the decal im wanting off ebay..im not sure what size to tell him to make..
what gen? the humps are a bit different on the sides so it may change what you're looking for. I got an 09 with a custom vinyl I can take a picture of later tonight and up for you - i'll get the specs for you as well.
Keep in mind that if you go too big you'll need to put it on wet and use a hair dryer/heat gun. You'll need it wet to be able to move it to exactly where you want and then wipe the water and bubbles out(which isn't a bad idea with smaller decals too), and the heat will let you get the kinks out from a big decal not fitting flat on all the curves of the hump.
