I jusst installed a Micron full exhaust. I also did the pair block off mod. When I start her up eveything seems to be ok. Then I see smoke coming from the airbox. Is this normal?
Thanks,
D-
<!--EDIT|Cuffee
Reason for Edit: None given...|1123384133 -->
I think what happened is that I used some gasket sealer and it was probably the cause of the smoke. It's not smoking any more. I was sure scared for a second!
shenoyp he said he did his pair valve . Did you block off the hoses at the air box and carb??? If so that is a new one on me... Johnnycheese to the rescue please
