Hi Everyone,
Last fall I bought an '02 hayabusa - love it.
It came with 2 chrome rims that were not on the bike. So this spring I decided to put them on.
I removed the rear wheel and realized I needed to replace the bearings and seals, I ordered bearings for the back and front. Got them, installed in rear wheel, had tire swapped. Wheel went on fine.
Here is the problem. When I removed the front wheel, I immediately noticed the bearings I got were too large to go into it. On close inpsection I also noticed the rotor bolt holes dont line up, bolt pattern is just slightly larger on the rotors. The rim generally looks to be the same "style" as what is on there, but the center is not a definite match.
I can't afford to get my front wheel chromed ( they quoted me 900$ at my local plating company), I want to sell this rim or trade it for one that will work. But I dont know what it goes to! I took it to the local dealer but they couldnt tell me for sure. I am posting some pictures of it, and really hoping someone can identify it indefinitely for me.
Couple of peices of info. It seems to match the rear rim, so I wonder if another model of bike shares the rear rim specs, but the front rim is different. Also, I got hold of a micrometer and measured the bearing seat or bore, it is 47mm, so whatever this fits would take a 47mm set of front bearings.
Thanks in advance for any help. Truly appreciated.
Todd
Todd
