need help with air shifter
02bluebusa
How do you hook up the horn button to make it shift? I have everything hooked up but that.
I have looked and read alot but can not figure it out. It is a 01 busa with the old ignition kill from muzzy
(Not the digi kill) there are two wire coming from a relay, one black and one red.
Those are ran up to left front side of bike and only wires not hooked up.
There's a connector. Coming off the (2001 sup man) horn switch / button is a black with white wire and a black with blue wire you want the black with blue. On the horn side of that connector the wire color is black. Check it out. Hard for me to read.
I forgot to add i bought the bike this way. I was told that it works i just need to hook up the horn with toggle switch(somehow) . Coming out of the harness there is a black wire that goes to the ground post on the battery.
Maybe the red wire goes to 12v ignition so it only comes on with the key on and the black wire goes to the horn/toggle for it to work.
Second photo shows the relay with a diagram on it. An expert will be along.
Is that your shifter selinoid in the trunk. If it is...move it closer to the ram...preferably attached to the ram.
