Has anyone bypassed the secondary throttle blades motor with a resistor or looped a wire or disconnected a wire to eliminate it? I need help to eliminate the servo completely and trick the bike into not throwing a code. This is an 08 by the way.
Also I need to do the same thing with the exhaust servo on my B King. I want to take it off the bike completely but I need some wiring fix to not get a code.
Thank you, Steve
Thank you, Steve
