coreywiley
Ok here it is! I have an 08 busa and I'm trying to install a i900 scorpio alarm system on it. The problem I'm having is with the RID-5 or ignition Disable/hijack module. I read Icemann post and he said that he used the orange/white ignition wires but he said that he used case his was different and under that the instructions said to cut the yellow with green trace wire. I cut the y/g wire but it didn't work am I doing something wrong should I cut the o/w wire. I included some pictures of the wires on my bike and where they're located. the first picture is the o/w wire and it's coming frome under the fuel tank. The second picture is the y/g wire and it's located on the starter relay coupler. which one should I be using?
