need help with rearsets
Gspot
i just had my rearsets powder coated. when i went to install them back on the bike i noticed that they have alot of play in them now. i have the washers on and the bolts as tight as they will go. i never really noticed how much play was in them before. if someone could help me out id appreciate it.
I haven't dealt with them much, but there is a lot of posts with a PDF manual. I would recommend a search for that and make sure any and all washers/bushings are in the correct places.
gary give me a call --i can help you solve the issue over the phone---i also have the bushings they took out if you need them.
The rearsets do float a little on the frame. I believe it's an effort to reduce vibration.
