CTA_Busa_LE
Well I installed a full Muzzy on my system earlier in the winter. I had the typical clearance issue between the line to my oil cooler on the left side of the bike and the header. I have road tested the bike since, put maybe 30 miles on it hoping I had enough clearance. Well just my luck it was already starting to show wear on the oil line.
In an attempt to correct the problem I have added three small washers behind the lower oil cooler brace to push the cooler and line toward the front tire and away from the header. Yes they were a trick to get in there but I got it done.
Any opinions on the clearance or my method of fixing it. I can't see where this will create an issue in the future and right now there is a full 1/4 inch, maybe a little more, between the oil line and the header. I would much rather resolve any future issues now so any and all input is greatly appreciated.
