Ok, I had posted this in busa problems and didn't get much response I guess because there isn't as much traffic thru there as here. Did just see one response and I will check into that here shortly.
But my problem is with a 08 with clutch slippage. Originally started out thinking plates were worn and also from opinions of others thinking it was the same. Funny thing is that it just started happening all of a sudden, no leading up to it with gradual slipping just bang straight to the punch. Well, ordered brand new OEM frictions & steels and replaced them. Took out for test ride all seemed fine at first and then I guess it got warmed up to good temp and started same thing again. Under advise of others pulled it down again took measurements of stackheights(old & new discs) ended up with new discs stackheight is shoter than old discs. Around 1.9820 on old compared to 1.9720 on new discs??? New fibers are .002 thinner than old ones and the 2 thick steels are .001 thinner, others are fine. So under some more advice from a couple people I tried replacing one of the new thinner friction plates with the old outer friction from old stack with is thicker under the assumption it would build up the stack height thicker than old height which in theory would bring it back up to or above original height. In turn may end up with a little less clutch room between engaging and disengaging but should fix the slipping problem right?
Anyhow pulled it all back apart rechecked and replaced a thin with the thicker plate, everything has been re bled put back together and out we go again to see if it worked. Well it seemed to take a littler longer this time but she is back to the same scenario. Once up to temp if you go up thru the gears easy it'll seem to be ok, but if you go to give it any throttle she will just spin up the rpm's and it acts just like your spinning the rear tire trying to get the power to the road which it evidentally isn't that. Even if you roll on it more gradual it will still slip but just not as drastic.
I went out and took this quick little vid(sorry for the buzzing as I just hard mounted it to tank) and you can clearly see it doesn't matter what gear you are in it will slip away if any additional throttle is applied. I'm scratching my head dumbfounded here. Anyone?? I know there has to be someone else on here that has experienced this problem and has to know what is going on here. lease:
