I have a gen 2 and I think I have some play in the swingarm, when I lift the rear off the ground with a rod through the swingarm pivot sitting on jackstands, I can grab the rear wheel and pull it to the clutch side of the bike and see the entire swingarm move about .25 of an inch. I took it in to the dealer and they tore it apart to check everything, they told me they could not find anything wrong and that the play was normal, I am having a handling issue and I believe this is where the problem lies, could someone check on there bike and see if this is normal or not, Thanks!
