First,
to the site. Congrats on the new bike!
You gotta download the service manual hosted on this site (thanks NICKSLICK) -
here is the link to the thread. So, you can do your own maintenance and troubleshoot issues.
If the bike shows FI light consistently, the ECU (Electronic Control Module) stores the codes giving more details. In order to see the codes on your display (where the clock is shown), you need to switch the bike into a dealer mode. If you lift the seat, on the left side of the bike, closer to the hump there is a seemingly unused female connector which has only two wires inside. Just put a clip in there while the bike shows FI light, and it will start showing one or more codes. Simply look them up in the service manual starting on page 4-29. It also explains more about dealer mode. Let's see what codes you come up with..
I actually installed a micro switch under the hump and connected it to that connector, so I can easily switch to dealer mode if/when I need to read the code.
