III
Took some time off work today and I finally (after a year or so later) got around to connecting my laptop to the pc3 and having a look at the map that was used by the installer of my exhaust. I did not have it dyno'ed, but rather a copy of a map with the exact same components that had been. So I went to PC's website and got their map for my setup (minus the stacks as there was no option) and compared the 2.
I can pretty much guess what those numbers mean inside the cells of the Power Commander program, but there's a HUGE difference between the two maps, and I was wondering if the differences I'm seeing are really bad or if I just have no idea what I'm looking at/talking about.
As far as the butt dyno's concerned, I almost like the suggested map vs. the installer map, but that could just be all in my head. I haven't made any top end runs yet since I swapped out the map, but low end feels like it has more power or snap (which seems odd to me since the numbers are significantly higher on the installer map). I don't get to the track nearly as much as I need to be with this setup, so I rarely see the top end this setup was designed for. Is the installer map overkill for the type of riding I'm currently doing, which is commuting, occasional 1-2 hour rides w/ friends, etc.?
Can someone who knows more about pc3 tuning help me understand this?
Here's another question/factor in the equation...I did have the ECU flashed with the editor so the top speed restriction was removed and the LOW and MID bodies adjusted by editor as the pc3 is still controlling the HIGHs (which I believe I was told...its been a little while now and I just been ridin it). So at this point, since the pc3 is still hooked up, I'm totally confused as to what's really in control...that or ECU flash, or as stated above, a combo of both? ???
