I've searched older threads and I've seen Spider grips, Harris grips and Pro Gel grips typically mentioned. Looks like 125mm? is the proper replacement size although I see many only come in 120mm. FYI, I've read how to remove (screwdriver, alcohol) and apply (hairspray). As an avid tennis player I'm even considering Juggler's idea of putting on quailty tennis raquet grip over the existing throttle. From experience I can say there are some super comfy, thick, sticky grips made and it would allow you to customize the diameter of the grip to your hand size.
1. What grips would you highly recommend for control and comfort?
Second, I'm contemplating the Stomp Grip pads for the tank while riding at the Bash. Not crazy about the looks but from what I've read they work amazingly well in helping you control/support your body in leans and stops with your legs/knees.
2. Do these come on and off w/out adhesive?
3. Are there other recommended makes of this type of product anyone is using?
Thanks for the input.
