only input i can give you is on the adjustable links... i have them and love them. your not subjected to having to lower it to 1 of 3 preset positions... you can put it where you want and when you want because with the adjustable ones you dont need to get the weight of the bike off the swing arm like you do to change the position of a dogbone style lowering link. You just loosen the two jam nuts on both adjustable lowering links and turn both links equally, retighten jam nuts and your done. Dogbones you have to get the weight of the bike off the suspension to pull the bolts out to reposition the dogbones and reinstall the bolt, i guess its fine if you have the tools and a buddy to help you... just my .02's
