Maxxxpath2
Just passed the 600 mile break in and had her serviced at dealership yesterday. Bought the new Busa three weeks ago. On day 1 the dealer set the RPM max to 5000 on the SDMS which was fine. Indicator lights worked fine and I could get bike up to 80mph. After my first service I deactivated the RPM max and headed home. I quickly realized the throttle would not push the bike beyond 80 to 85 mph and about 4500 to 5000 RPM.
I pulled over and called the dealership and they had me reset to 'default' factory settings and that did not fix the issue. I finally created a custom SDMS 'U' setting where I turned off ALL lift and traction controls. Have not yet been able to test to see if that works. That doesn't feel like that should be the solution so I'm checking with the forum. It's almost like the 'Active Speed Limiter' is ON but it's not. Anyone had this issue and what was the solution?
Thank you
Robert
Thank you
Robert
